HumdrumPenguin
I see you guys talking about volume such and such using Tidal, do make sure you have Exclusive mode enabled in Tidal as well.
For the record, I listen to my 6XX at about 10:00 on high gain with the Asgard 3/4490 in Tidal. It shouldn't be compared to an Asgard 3 with Bitfrost 2 because there will be a large difference in volume.
The discussion about volume is that @Sean_MR is not getting enough volume with the Asgard,and we are trying to figure if everything is set properly to avoid sending a complaint to Schiit on an otherwise perfect unit.
