lpd2
ASR review came out a month or so after I got mine. I am not well versed in the technical bits but the review made it seem like I am undervolting the amp via the DAC?? I guess I should order an outboard DAC to see if I hear any difference. Reviewer made it sound like a pretty bad DAC but on a great amp. What spec am I looking for in a DAC so I don't make the same mistake? Any advice? Leaning toward the jds Atom dac.the T1 is rated for 300mW and 102dB, so very unlikely that you will need anything close to the amplifier's max power output (hearing and/or headphone damage very likely). I would expect typical max listening levels in the 9 to 12 o'clock range of the volume control (< 1/10th of max power). IMO, spec-focused sites like ASR don't provide enough data to determine how equipment will actually sound (because present technology doesn't measure the right things and/or hasn't properly quantified the physiological aspects of human hearing).
IIRC there were two versions of 4490 module, the G2 being the newer one with OPA1662 active filter stage. not sure which one was tested by ASR.
New headphones need break-in time also (bass and midrange get a bit fuller, and improved dynamics)
