- Feb 1, 2011
driving my AKG K518 from headphone out, half volume (eu capped) low/medium listening volume, the battery lasted 24 hours playing ALAC.
Does the battery life change when using the line-out instead of the headphone-out? I've never tried the line-out of my Touch.
Hi,
Does anyone have any idea if the clip zip can be rockboxed using clip+'s firmware or when the firmware for clip zip will be out?
Thank you.
i'm testing battery life with LOD now, been playing for 11 hours so far
only 25 hours, so not much difference, this is all playing lossless, leaving it playing constantly. So headphone out at low/medium volume 24 hours, LOD out 25 hours.
This is all non-scientific and just a home experiment.
Regards
Clip+ firmware does not work. Rockbox for Clip Zip is available now for the experienced user, if you know where to look.....and one of the developers said the other day that it would be available in the Rockbox Utility very soon for everyone else.
So if I were to get a player now, I should invest in the clip zip instead of the clip+?
Thanks for the prompt reply!
