Is your case like mine, where support clearly WAS there, because it used to work with my specific unit, and now it doesn't, or are you trying to connect to the DAC for the first time? If you told them it was working with the old version but isn't under 5.0.1, I wonder what their reply would be?
Plus, you can find similar issues reported as far back as February, so this issue seems to exist on multiple ROM versions of the Lollipop update. If shabta's unit is working without going through UAPP, then it's the only one I know of that's confirmed to have working USB audio after upgrading. I doubt this is a simple as Exynos units are working, Snapdragon aren't. though. I suspect it's more likely some regional ROM releases work, and others don't. We need more data to form a picture.
