I cannot compare the bass management on the ES players and the DVP players since my C333ES is strictly two-channel.
My setup relevant to this discussion:
DVD/SACD - DVP-NS500V
Receiver - Outlaw1050 (Processing and amp for C and R & L surrounds
Amps - Adcom 565 (Front R & L)
Front Speakers - Polk SDA-1C
Center Speaker - Polk CS-200
Rear Surround - Larger Advent
DVP-NS500V is connected via optical toslink for DVD-V playback of DD and DTS audio. DVD input on receiver is matched to optical in 1. In this case all decoding, speaker settings and bass management is handled by the Outlaw 1050.
DVP-NS-500V is also connected via 6 analog RCA inputs to the 5.1 direct inputs on the Outlaw 1050. In this case the Outlaw does no DAC or DSP decoding of the signal so all decoding and bass management of these inputs are performed on all signals coming from these jacks. Since I only send the SACD signals there they are the only ones affected. The following speaker parameters can be set:
SIZE:
FRONT - Large; Small
CENTER - None; Large; Small
REAR - None; Large; Small (You can also set them as rear/side but that setting only affects DD, DTS or PCM sent to the 5.1 outs)
SUBWOOFER - None; Yes (xover set at 120 hz)
[My Settings - Large; Small; Small; None]
DISTANCE
FRONT - 2' to 50' by 1'
CENTER - +2' to -5' (relative to front) by 1'
REAR - -16' (relative to front) by 1'
[My Settings - 12'; 10'; 8']
BALANCE
FRONT - -6 to +6 dB by 0.5 dB
REAR - -6 to +6 dB by 0.5 dB
[My Settings - 0 dB; 0dB]
LEVEL
FRONT - -6 to 0 dB by 0.5 dB
CENTER - -12 to 0 db by 0.5 dB
REAR - -12 to 0 db by 0.5 dB
SUBWOOFER - -10 to +10 dB by 0.5 dB
[My settings - -3; -1; 0; NA]
There is also a test tone for setting levels
Remember I do not have a subwoofer at this time so the fixed 120 hz xover is not a problem for me. So there is bass management but it is probably better to describe it as bass redirection. For true bass management I will likely purchase an
Outlaw ICBM and insert it between the 5.1 outs of my DVD/SACD and the 5.1 ins of my receiver/pre/pro once I purchase a sub.
