Not too sure, 9038 Pro consumes as much power as 3x of the 9028 Pro with a little more gain in performances. I don’t think 9038pro is ever intended for Portable player. Neither does 9028pro. These lines are intended for Desktop uses.
There is only so much to cramp into a portable design. One key example is the Battery power DC supply vs Real AC main.
^ Still, nobody else has an ES9038Pro DAC as low as Oppo's $799 offering. Other manufacturer's ESS ES9038Pro implementations are priced far higher than the Oppo Sonica DAC.
L.K.S. wants $1260 for the "standard USB" version of their dual ES9038PRO, so some might argue that's a better deal than the Oppo Sonica DAC, in that L.K.S. isn't asking $1600 (twice the cost of a Sonica).
That's without the USB card. Which adds another US$80.
As for the Aliexpress listing, look around, there are other similar listing for less. I have not heard them but I would tend to think that swappable op-amp chips would be be a nice feature to be available on these DAC's.
The particular model has soldered op-amp chips though.
