Hooster
- Nov 4, 2010
Probability is low though because i don't have this problem with any other amp. My new amp has the same type of powersupply and is quiet.
So what is causing your problem then? How is your amp different from all the thousands of silent one's that are being used all around the world? I don't think it is the amp, I believe it is a combination of dirty power at your location and the power supply that comes with the rnhp. This is easily solved by using a different power supply or a filter. You should give that a try before returning your amp. Mine is silent, even with the volume turned up to the max with iems...
