arijitroy2
- Jun 29, 2015
This is not true.
This is true only if you are using a Network DAC, Any USB DAC can work with the Roon Bridge using RAAT.
Thats what the OP I asked, by his question, I am assuming his Roon Core is in a different room and DAC in a different room. So he can use the devices from those company, load it with Roipee and make the DAC an endpoint.
If the USB DAC is not Roon certified, then he has to connect it directly to the Roon Core if he wishes to avoid using the other devices.
