Originally Posted by luvdunhill /img/forum/go_quote.gif
Given unlimited heatsinking for the pass devices, how much current can the sigma22 provide before the fact that the rectifier diodes aren't heat sinked (and are in relative close proximity) becomes an issue?
You need to qualify what "how much current" means. Is it continuous duty? Or is it short duration peaks? If peaks, then is it repetitive or not? If repetitive, what's the duty cycle?
Assuming continuous, the current limitation will most likely still be limited by the MOSFETs' thermal resistance (and any isolation pads/thermal compound used) even if you use huge heatsink(s). The total thermal resistance is the sum of the device's own thermal resistance, isolation pad/thermal compound thermal resistance, and heatsink thermal resistance. At some point as you increase the size/efficiency of the heatsink, its thermal resistance becomes a small portion of that sum and the MOSFET's own thermal resistance becomes dominant. This is a factor in the computation of the junction temperature, which is outlined in the "board and heatsinks" section of the σ22 website. You can plug in a very low number for Rsa in the equation and see for yourself.
Other than that, the rectifier diodes and power transformer are the other limiting factors. Assuming you use MUR820 rectifiers, the forward drop (Vf) is slightly less than 1V, the instantaneous power dissipated on each of them is the current through it multiplied by Vf. But, keep in mind that the current through the rectifier is not continuous, but AC pulses, so the average power is much less. These are rated at 8A, and can pass much higher peak currents. In normal use situations they will not need heatsinking because we'd have reached the thermal limit of the MOSFETs first.
If the load is pulsive in nature rather than continuous, then σ22 can deliver a lot of peak output current, well beyond the calculations based on continuous duty. How much is "a lot"? Well, it depends on the nature of the load current.
