Roll Call: Who's building, built, or thinking of building a beta22?
Nov 20, 2009 at 8:24 AM Post #1,996 of 3,218
How precisely do i check my tree i disconnect it from the inputs only or everything ?
I did do the intial check before wiring up all my readings seemed ok i let it warm up for 10 minutes and all my Dc offsets were 0.0 - 0.1 mv
i assumed the .1mv is ok ?
Edit: im double checking it again after letting it warm up some
also when im measuering from input L / R to output L / R what exactly should i be looking for ?
Nov 20, 2009 at 8:43 AM Post #1,997 of 3,218
You can disconnect just the signal input and signal output on the Tree assuming you didn't hardwire/solder them. We only need the Tree working to make sure it works as intended. Your DC offset is fine.
We're checking to make sure that the resistance across the respective channel follows the volume. For example, when the volume is at 0%, the resistance across left.input & left.output / right.input & right.output should be a very high number. On any volume, the resistance of the left channel should be similar to resistance on the right channel.
If the volume is at 0, we expect very high resistance (for example, 50K ohms or infinity). If the volume is half way, we should see for example 30K ohms. If we maximize the volume, we should see low ohm. The higher the resistance, the lower the volume, and vice versa.
Nov 20, 2009 at 8:58 AM Post #1,998 of 3,218
ok did that check im getting 1.821 k ohms regardless of volume setting im assuming the amp had to be on ?
on one board the reading is 1.821k ohm regardless of volume
second board its 1.821kohms at lowest
than 700~ ohms at full
you think my ribbon cable could be the culprit ? the top cable doesnt look like it sfully through but i cant seem to get it through
Nov 20, 2009 at 10:12 AM Post #2,002 of 3,218
I would give the boards another look and see if you bridged anything or missed a joint, or maybe swapped orientation of a chip. Your ribbon seems to have the red stripe on the left, and according to TPA's site it should be on the right side.
In the meantime if you have software volume control you can tie your signal wires together (ground can go through Tree) and see if your β22 is making some music. I think -60dB is okay; be careful, it can get VERY loud.
Nov 20, 2009 at 10:37 AM Post #2,003 of 3,218
im redoing my sanity checks and if i have the molex plugged into the board (input) i am getting a different reading as compared to when it is unplugged? any reasons for this...
and when its plugged in on the opposing ground pad when im using it to measure dc offset the lowest i can get it is about 30 mv
but when i unplug the input it can get down to 0 mv
you think my source can be adding some voltage to the system my source is a buffalo 32 btw
Nov 20, 2009 at 10:48 AM Post #2,004 of 3,218
It looks like you dont have the cover on the connector which will push the cable down. You seem to be trying to put two ribbon cables on top of each other, it will only take one.
Nov 20, 2009 at 10:54 AM Post #2,005 of 3,218
i had actually read somewhere that it can take 2 and thats how you were supposed to do the balanced jtree... but they broke =x so i just forced teh cable down on it it is working now i pushed a little harder and i am measuring dif resistances in both boards
now im just struggling with my dc offset issue
Nov 20, 2009 at 11:17 AM Post #2,006 of 3,218
Your source will add voltage, even more when music is playing, although 4Vp-p (balanced) is idle for the Sabre32.
Nov 20, 2009 at 11:45 AM Post #2,007 of 3,218
i think i have narrowed down my bad sound quality problems i think it may be my cable from the dac to the b22... is it possible for you to make a cable so bad that it is all garbled... bass sounds like its ripping n generally teh sound is like gurggling.
Nov 20, 2009 at 12:12 PM Post #2,008 of 3,218
Check the continuity from the pins.
Nov 20, 2009 at 12:35 PM Post #2,009 of 3,218
well if the continuity wasnt the same wouldnt it not play ?
i can hear music just not very well ... or do you think i may have the + - reversed ? will that even work ?
i did check the resistance and got .2 ohms for every pin
Nov 20, 2009 at 1:04 PM Post #2,010 of 3,218
Set your DMM to continuity beeper, make sure there is a beep between wires on either end of the cable. Ground to ground and signal to signal etc, if there is a gross error you’ll hear “no beep”. Check continuity between the opposing wires there should be “no beep” again if there is, the cable is probably faulty.
If this checks out maybe have a look at your Sabre32 outputs and make sure everything is ok there.
