does the coffee have the powered thingy on the cable too? Do you know if that takes the place of needing a isolator?I have the Project S2 Ultra + Audioquest Coffee USB cable (which I got for almost nothing).
It's glorious. Better than AES from Metrum Ambre, which in itself is a great source.
Rockna Wavelight
- Thread starter koven
I prefer the ProJect S2 Ultra (USB) to the Pi2AES (I2S).
EagleWings
Darn. I wonder how I get truly bitperfect on OSX. Thanks man.
If you used the free version of the VOX, it is not bit perfect. I learnt this only a few months back. All the applications I know that can bypass the Apple MIDI and output bit perfect are not free. But you can take advantage of the trial period these applications offer and use it to update the DAC FW. But as you will be needing a bit perfect player for future FW updates, I’d recommend buying a license.
ufospls2
- Dec 9, 2014
I'm on OSX Big Sur, the most recent version. Im guessing VOX was a spelling mistake? I'll look into it, thanks man.
EagleWings
VOX is actually a minimalistic music player for Mac. It comes in both free and premium versions and only the premium version does bit-perfect. VOX's premium version is a subscription model. So if someone is paying for a music player, they might as well get something like a Jriver, which offers a lifetime license (for that particular version).
ThanatosVI
@ThanatosVI Have you looked at getting a Pi2sAES? It would be really interesting to compare that to the wavelight server.
this video got me thinking that maybe it just the clean nature of the sig from server is what makes it sound so great. (and it seems the pi2saes is super quite. I ordered one but i'd have nothing to compare it to other than the PC. (is is also a TON cheaper and $4300 is a lot for a steamer.)
Nah since it would be only temporary, I saw no need for that
ThanatosVI
Back in black boys
This new unit also instantly connects to my galaxy s10 via app
The old Wavelight I had before refused to connect with my Smartphone and I always had to use my tablet
ah.. black is much nicer
Welcome home Mr Rockna ThanatosVI
Did you notice any sound changes from the old and new unit? (ie "burn-in" in unit vs new?)
ThanatosVI
No, there were several weeks in which I had to use a different DAC. Audio memory isn't that accurate over 3 weeks.Did you notice any sound changes from the old and new unit? (ie "burn-in" in unit vs new?)
However there is a huge difference to the other DAC I used, I'm so glad the Wavelight is back!
What other DAC?
ThanatosVI
I used the Oppo Sonica DAC in the meantime. Which is a Delta Sigma DAC Based on an ESS Sabre chipWhat other DAC?
tamahome77
Does it enhance the sound quality of your Rockna's USB? Or do you prefer it in a versatility sense?I prefer the ProJect S2 Ultra (USB) to the Pi2AES (I2S).
I thought you sent your unit to replace the outer part to change colour. Did they replace the inner part as well?Back in black boys
I am glad that you are back to the right sonic environment.
ThanatosVI
I honestly can't tell if they switched the outer part, gave me a perfectly looking black b unit or even a new unit.I thought you sent your unit to replace the outer part to change colour. Did they replace the inner part as well?
