Balkan
- Mar 14, 2013
I guess it's true. I would be common sense beeing a major product alteration. Not sure anyway.
I didn't use any glue. Just wanted to keep thinghs, you know... clean.
However, the dab of epoxy that 23t23dS is suggesting sounds like a good idea so I might be reconsidering...
Any chance you could post a picture?
Question for you... I really am thinking about removing the memory wires like you and others, but I also assume that will void the warrenty? Any idea if that is true?
I was thinking about maybe putting a dab of some sort of glue which has a bit of give in the little hole areas where the wire connect... but not sure if this will help or hurt the connections in the long run.
I removed the memory wires too and strengthened the joints with a dab of epoxy
