Heng2010
- Oct 20, 2016
Can I can add Thai fonts to the firmware?
Thank you
Suchart
Thank you
Suchart
Can I add Thai fonts to the firmware?
Is there a Thai font files for adding to this firmware?
or How can I convert Thai fonts file from OS Ubuntu v 16.04 to Rockbox files?
Thank you
Suchart
Hi did some one knows if its possible to emulate to play the songs at 432Mhz?
thanksHi did some one knows if its possible to emulate to play the songs at 432Mhz?
You mean 432 Hz pitch? Set the pitch adjustment to -1.8% (assuming source is 440 Hz anyway).
To anybody considering buying the XDuoo X3, or for anybody who already owns one and is not sure whether installing an alternate OS on the device is worth the effort: Rockbox turns this already cool player into an amazing piece of gear. Shout out to Roman who did the Rockbox port for this device...you did an awesome job. We should all be hitting the donate button on his website!!! http://xvtx.ru/rockbox/ Seriously, thanks, dude.
I can't explain how happy I am to have Rockbox running on my X3. I was starting to think that Rockbox was going the way of the dinosaur (seriously, aren't there enough Clip users still around to justify at least one update since 2013?) If you check out the original Rockbox site, you'll see a bunch of near-extinct supported devices. I have been running Rockbox for several years on an iPod Video 5.5 Gen (yes, the one with the Wolfson DAC...which is hugely overrated, in my opinion). It was an upgrade from my ancient Rio Karma, but never really sounded very good -- it couldn't come close to any decent CD player in SQ, but I used it because Rockbox gave it support for every music file format in a slick interface.
Now, thanks to Roman, I have a new, cutting-edge device with killer SQ that runs Rockbox like a champ. This thing sounds amazing, y'all. I am surprised that the X3 has only made a small splash on Head-Fi thus far. For the budget-minded audiophile, it's the cat's meow. It sounds better than any CD player I have tested it against so far...clean, neutral, fast, and super-detailed. My iPod sounds downright slow and muddy in comparison. The X3's only real fault is that pesky timestretching glitch in the stock OS, and Rockbox eliminates it entirely. Rockbox also gives me awesome EQ, which I've just begun exploring. And to me, it is just a very intuitive and attractive interface.
I guess I'm a fanboy. Go X3. Go Rockbox. Yeah.
Have you tried just naming the "rockbox full" file to "update" without the extension ".zip" ?
If you rename it "update.zip" , the OS also add another ".zip" becuase it recognizes it as a zip file. So you end with the systen seeing "update.zip.zip".
That is invisible to you, but that's what the system reads.
