JackiesFridge
- Dec 28, 2015
.... while in my pocket a big sequence of different buttons are unintentionally pressed which results in a completely messed-up (in terms of badly-configured) Rockbox environment. (Most of the time it actually also freezes.)
You can probably email XVortex and ask, but I'm assuming the bootloader is relatively set in stone. IIRC, all Rockbox targets with dual-boot rely on the hold switch to choose, which makes it very handy, especially if something goes wrong with one firmware or the other, you'll still be able to boot into something and troubleshoot.
I'm not sure how Rockbox gets messed up, though--with the hold switch on, the Xduoo will boot into OFW, not Rockbox. That should have no impact on your Rockbox settings. If it does so because you've given up on engaging the hold switch, I'd urge you to use the switch anyway, just to keep your Rockbox configuration intact.
In the mean time, I'd recommend finding (or making) a cheap case. That will usually make the power button more difficult to press accidentally. I would also recommend saving your Rockbox configuration settings once you have them as you like them--that way you can restore your configuration easily. I'm sorry I can't provide more meaningful help.
