barbz127
- Oct 8, 2009
Confirming both.
Banana to harbeth p3esr and spade to rel tZero here.
NiceAIC10 terminals are compatible with bananas, spades and even bare wire.
Why do you change tubes so often?i changed it thousands of times, it did feel scary at first, but it really is ok
its a figure of speech of courseWhy do you change tubes so often?
The switch on the front mutes the speaker outputs when in headphone mode but the headphone outs are always active.For you folks using both speakers and headphones... do you need to unattach speaker cables when listening to headphones and vice versa?
ThanksThe switch on the front mutes the speaker outputs when in headphone mode but the headphone outs are always active.
If you wish to use speaker tap for both headphones and speakers you would need an external switch box
This was exactly what I was planning to do. Thank you.I detach my headphones when listening to speakers. But not the other way around![]()
I use very old Dynaudio Audience bookshelf speakers. They sound fine, but not great. I don’t use them because they are particularly great with the amp but rather because I didn’t have time nor money to go speaker shopping. On my auditioning list would be Audio Note, Cube Audio, Blumenhofer and possibly Fleedwood.This was exactly what I was planning to do. Thank you.
What speakers do you use? Seems like lots of AIC owners use speakers too with the amp.
make sure to get the Barnett convolution filter for the CA-1aI finally received my Raal CA-1A/TI-1B interface and Star-8. Pure Silver Cable. Still need to burn in but they do sound wonderful with the Riviera so far. My question would it be better to use the 32 ohm or 16 ohm input on the TI-1B interface. Currently on 32 ohm
