I have no experience with SMD whatsoever. I've stayed away because it's just too small to see, even under a lighted magnifier. That all changed yesterday.
I finally got around to the Mini3. The first step is to install the SMD chips. Question is, how?
I've been wanting to try out the Zephyrtronics pyramid looking air pencil. It's touted as having slow air flow, unlike the normal hot air tools. The slower air is supposed to make it suitable for any type of soldering.
There are two problems. First, the pencil doesn't seem to get hot enough. The temperature air that comes out of the pencil depends not only on theheat settings, but also the speed of airflow. But it couldn't melt my 0.062" 60:40 solder at any settings. Even the 0.020" 63:37 was a little slow. I bought this unit used, so maybe it needs calibration or repair.
So I know this is going to be a rough job with the air pencil. This is my first time using the Zephyrtronics, so it might just take some getting used to. Stupid of me to practise on an expensive chip, instead of some throw away parts.
Out with the solder paste. I don't know how anyone can work with such small parts. The paste comes out of the syringe as huge globs compared to the traces. Well, it's supposed to work just fine globbing it all over the traces. The flux is supposed to do some kind of magical attraction thing I remember hearing about vaguely in Chemistry class, so I just globbed the gunk all over and hoped for the best.
Working under the cheap lighted magnifier, the solder looks like it flows, and I was able to get it to where it looked good at 2.6x magnification. The chip was a little off center, but looked okay. It did take longer that I was comfortable with, but not so long that I was really worried.
But the microscope told a very different story. Under the microscope it was a mess. There were blobs and splashes of solder beads everywhere. (The solder paste is made of tiny beads of solder in some flux fluid.) One mound melted and nestled between two leads and hid out mostly behind the leads, under the chip. There were other potential solder bridges all over the place. Okay. easy enough to fix. just need to flow it more.
No pictures of that because they didn't come out. I'm still struggling with the camera and lighting. The mirror in the camera shakes when it takes a picture, which blurrs the picture. Wish I knew about this before buying the camera, since other models are available that move the mirror first, then settle down and take the picture later. So, apologies for blurry shots.
So after a whole lot more heat... I could see flux rippling around, but there was no visible clue about whether the solder was melting or not. I had to grab the visor and keep flipping down the magnifier to check. It finally looked good.
Well, here's one chip. You can see how it's misaligned, but it should work just fine. The solder splashes are gone, and there aren't any more visible shorts, but it took a long time to get there. Two of the traces are burnt, and I'm not sure the chip itself survived the heat.
Moving in a little closer reveals how much solder is still on the board. There's two traces of solder coming off the top right pin. They're not touching anything, but still. You can also see some unmelted solder beads splashed around the board.
Both of these closeups were taken after about three heavy sprays of solder cleaner, but I didn't wipe, just spray. This next picture shows just how much flux is still left between the leads and under the chip. Before remelting, there was even more flux, and it was full of solder beads. You can also see the condition of the chip in this picture. I'm not sure if the stuff melted on top of the chip is splash from the solder paste, or something on the chip melting, like maybe the ink.
Score:
Zephyrtronics -1
Mini3 -1
Cheap lighted magnifier -1
SiBurning +1
+1 for me? Yes. They say we learn from out mistakes until we can repeat them exactly. Next time I try to flow something, I might pull out a small tip with a better air machine. Meanwhile, I have to find out more about that pyramid looking thing.
