[size=medium]Hakko FM-2027 Soldering Iron Handle[/size]
This is Hakko's top of the line soldering iron handle.
Note the lighted ring indicating power, and the locking tab on the newer grips.
List Price: $80
Includes handpiece and accessories.
Supported Soldering Stations:
FX-951 Soldering Station
FM-203 Dual Port Soldering System
FM-204 Digital Self-Contained Desoldering Station
FP-102 Soldering Station (discontinued)
FM-202 Soldering Station (discontinued)
Temperature Control:
There is no heating element in the handle.
Instead, each tip incorporates its own heating element.
The element is specially designed for each tip to maintain the appropriate temperature with any supported soldering station.
No calibration required because the heating element is incorporated in the tip.
Tips:
The FM-2027 handle supports 81 tips in the T-15 line. The T-7 line of tips are identical except for the change in part numbers.
A variety of conical, chisel, knife, slot, bevel, conical, and hoof tips are available in straight and bent styles.
Specialty tips include blades up to 40mm, tunnels and quads for SOIC, TSOP, and PLCC packages, and a large mass chisel.
Tip prices vary considerably from $10-15 for standard tips to well over $100 for some of the specialty tips.
Tips can be changed easily and quickly without switching off the heat.
Note the lack of locking tabs on the older blue grip.
First Thoughts:
Very comfortable, pencil-like control and feel. Soft comfort grip handle prevents slipping rolling.
Tips can be changed in seconds while the station remains on.
Fast, precise heating of joints.
Great tip selection.
See individual stations for more information on heat capabilities.
Note:
The original handle has one annoying shortcoming: the tip would often slip off slightly without alerting you.
The way you knew was it cooled off and stopped working, and only then did you notice that the light on the handle was off.
The newer handle has a locking mechanism to prevent this.
The only quibble I have about the new handle is that it's a bit hard to remove, which is dangerous in a hot tool.
[size=medium]Hakko FM-2024 Desoldering Handpiece[/size]
List Price: unknown
Hakko FM-203 Dual Port Soldering System (with FM-2024 Desoldering Control Module)
Hakko FM-204 Digital Self-Contained Desoldering Station
Hakko FP-102 Soldering Station (with FM-2024 Desoldering Control Module)
Hakko FM-2024 Desoldering Module (requires separate shop air)
Desoldering temperature range is 650-840F (350-450C)
Tips:
8 desoldering tips are available.
Nozzle openings vary from 0.6mm to 2.3mm.
A 1.0mm extra long nozzle is also available.
Tips can be changed quickly without switching off the heat.
Tips are priced from $50-60.
Additional Features:
Removable gun handle allows the desoldering toool to be held like a gun or pencil.
Push button control of suction (trigger control in the gun configuration).
First Thoughts:
Quick to melt solder.
Easy to use, one hand operation (particularly with the pencil grip) and push button control of the vacuum.
Only works on through hole and point to point: not for SMD.
No need for awkward, jerking suckers or soldering wick.
Sucks a hole dry enough to pull off an 8-pin DIP after one pass.
Just make sure to move the pins slightly while the vacuum is on.
Requires maintenance of filters.
Gun configuration
Shown here in pencil configuration with long nozzle, tip remover in place, and solder filter removed. Also shown are the solder barrel cleaning tool, a regular length tip, the solder filter can, and the fume filters for the air pump.
[size=medium]Hakko FM-2022 SMD Parallel Remover[/size]
List Price: $250
Includes handpiece and stand. Tips not included.
The mini tweezers consume 140W.
Temperature range is 400-750F (200-400C).
Hakko claims an idle temperature accurate to 10C.
Each tip incorporates its own heating element.
Requires the use of both ports of a dual port station.
Tips:
13 tip pairs are available in the T16 line, ranging from a 0.5mm point to a 25mm SOP.
Tips are priced from $70 to $90 a pair.
Flange ensures accurate parallel alignment of tips.
Quick change tips.
Sleep mode functionality.
First Thoughts:
Tip Alignment. Note how the tip can misalign if you squeeze hard off center.
Side view
[size=medium]Hakko FM-2023 Mini Hot Tweezers[/size]
The mini parallel remover is designed for use with small chip components as small as 0201.
List Price: $275
Includes handpiece, 1 pair of tips, and stand.
The mini tweezers consumes 140W. (???)
Tips:
3 tip sizes are available in the T9 line, all under 2mm.
Tips are priced at $60 a pair.
Quick change tips.
Can be set to either open or close when squeezed.
First Thoughts:
They're not kidding when they says this is for tiny SMD parts. I don't know what type of resistors I desoldered, but they measure under 0.1" long. It's really easy to remove them with this tool. The only problem is one that happens with all tweezers and multi-side specialty tips--you need some way to quickly remove the part if you expect to reuse it.
If you apply pressure the wrong way when you squeeze the handle, it's possible for the tips to be a little off alignment due to the small plastic body.
Tweezers
