project86
- Feb 21, 2007
Will D100 stop sending signal to the line out when headphones are plugged in?
No, the DAC section is always active.
Pretty typical, though. This thing is really a DAC that happens to have a headphone amp - that the RCA outs are always active is not much of a surprise, although using active monitors myself, I get your issue (I run the Yulong through my RSA Stealth preamp, though, before heading to my Dynaudio BM5A's).
look forward to your updates on this. If this is a problem, I think that I will hold my money a little longer.
So I left the D100 on for the past few days, processing a 96kHz signal from the USB input and playing at medium volume to some IEMs. I have another component sitting on top of the D100, also turned on for burn-in purposes. So far no errors or issues. With the 2 units both on, the cases are somewhat warm, but not hot.
The weather this week is more mild than last week. I'm going to assume that the very high ambient temperature is what was causing my problem. I still have no way of knowing if it was a problem with the D100 itself or with my Dell Mini. But at this point it's not something I'm worried about. If we get another round of really warm days I'll be sure to test it again.
What are the differences between the low and high headphone output? How high should the headphone impedance be to actually plug it into the high output?
Bojamijams said:
shaggy said:
I know it uses that OPA21xx(forgot the exact number) for the headphone output. Does it use the same opamp for the RCA/Balanced outputs? If any at all.
