Esprit
- Mar 27, 2013
I like the fact I can plug them in directly via the XLR connection.
IMHO, using an active preamp or a buffer preamp is better
Thanks Elder.
I've tested on two different pc, win8.1 both, with the same effect...
I tested my DA8 plugged in my desktop (main computer) and in my notebook. Same problem on both. Both running Windows 7.
My HQPlayer settings on Mac OS (all PCM converted to DSD) and Yulong DA8 or Mytek 192DSD:
poly-sinc -> DSD7 -> 5644800 -> SDM(DSD)
or
poly-sinc-hb-2s -> DSD7 -> 6144000 -> SDM(DSD)
I use the DA8 as a DAC feeding my WA5 for both speakers and headphones. If you don't use hp that much I think the built-in amp is more than good enough.
Hi Esprit,
thank you very much for your answer. I shall try it, and let you know.![]()
I'm lucky: I converted my CDs in Flac as HQPlayer doesn't play Apple Lossless format.
Best regards...
Using RAMdisk Manager to improve playing on MBP.
