REVIEW - Yulong Audio Sabre DA8 Reference DAC
Discussion in 'Dedicated Source Components' started by project86, Jul 19, 2013.
98 99 100 101 102 103 104 105 106 107
  1. Elder
  2. guido
    Hi guys
    I just picked up a Yulong DA8 with some extensive modifications installed as detailed by the German company Hoer-Wege below which should bring it in line and maybe surpass the MkII version:
    This allows us to make the DA8 a truly excellent DAC. While the original device tendenziell rather sounds "boring" and "technical", the hoer-wege DA8 is wonderful "relaxed" and "transparent" !!
    The A28 replaces and supplements more than 30 components; 12 diodes, 24 electrolytic and numerous film capacitors, and the housing is damped, etc. The new components are of the very best quality, e.g. ultra-fast, soft-recovery diodes, excluding PANASONIC FM capacitors, WIMA slides, etc. By our modification, we achieve a clear "gain" in resolution and speed with "natural" and "real" sound.
    Optionally, we would like to use a more precise 100 MHz oscillator, the CCHD-950X-25-100. The exchange can be carried out 1: 1 if the connections of the CCHD are provided with soldered "legs". All in all, this modification takes more than 3 hours despite the "small" device. But it is worth it, because "after" you have a DAC and KH-amplifier, which also loosely with much more expensive devices.
    I am looking forward to comparing it to the internal DAC of the Aries Mini ...will report back
    I am especially curious to connect its XLR outputs to my Accuphase integrated amp!
  3. guido
    first impressions....very very good..I am really amazed at the level of detail and the soundstage presentation...I do not know how it compares to a stock DA8 but so far I am very impressed...and I have not tried the headphone output yet!
  4. guido
    does anyone have a link where I can download a user manual?
  5. guido
    Outstanding!!! I do not know how a standard DA-8 sounds but this Hoer-wege modded one is superb, definitely leagues above the BMC Puredac I owned previously..
    I am waiting for a OYAIDE CONTINENTAL 5 S USB cable to arrive...has anyone tried this USB cable?
