SlyFuu
- Jun 27, 2012
I'm looking to improve the bottom end as well as take some edge off the treble. Hopefully it'll improve the artificial sound I feel I'm getting currently with some songs as well.
Does anyone know what amp pairs nicely with these headphones? I'm currently driving them off of a onboard soundcard and was looking for something a bit more. I'll probably be using the hifimediy U2 dac.
I was thinking maybe the Schiit Asgard 2. Budget $250
I feel like I should revive this thread. I've been comparing this to the new Fidelio X2, and I must say the HP200 will be sticking around for a good while.
Thank you. Did you write a comparison? if so, where did you post it?
Can someone tell me about the soundstage. Some people say the soundstage is huge & airy while others keep saying the soundstage is small or on level with a hd650.
And how do these compare against Philips x2.
Hi, anyone worked out how to work the extension cables on the HP200, trying to attach all given cables together to use with an AVR headphone jack. Does not work at all. Possible to attach the short cable (screw adapter) but not the long one.
Surely i must be missing something really obvious?
Otherwise i'll have to get a third attachment to the chain (weakening the signal i imagine) with something on the end like this:http://www.amazon.co.uk/gp/product/B00KWAZQYI/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3F5VWH0OWF6UT
I do not think that there is a solution with the parts provided by Soundmagic.
The longer cable is an extension cable and has a non-threaded plug. The screw-in adapter (1/8-to-1/4 inch) only works with the short cable; it does not work with the plug at the end of the extension cable. To solve the problem, one could use what you show in your link, or a non-threaded 1/8-to-1/4 inch adapter, or an extension cable starts with a 1/8 inch outlet and ends with a 1/4 inch plug. The last solution allows you to have only two attachments in the chain. The middle solution requires three attachments, but one of them is an adapter without cable.
I read a review in which the reviewer complained about the provision of a threaded adapter in the box; I understood what the reviewer meant only when I tried to fit the adapter to the plug at the end of the extension cable! Soundmagic should have provided either an extension cable with a threaded plug or a non-threaded adapter.
