audionewbi
- Jan 24, 2010
If IE800 had better fit, if man for me it would have been more than enough.
Better fit?
I used to have problems with fit before, but I guess I just got used to ie800.
At first, it's one of the IEMs that you neeed to get used to.
On the other hand, ie800 has really bad fit if the tips are slippery, they do need washing!
The thing is not about getting used to it, it's that if none of the provided tips do fit, it's a lost cause since they are proprietary and you cannot easily adapt other tips.
Very bad design choice, Sennheiser sells too many models with different proprietary tips..
I haven;t had problems with fit at all, and one of the tip sizes should fit everyone. At the same time I'm not a fan of propetary designs..
None fit my ear canals, they're all too small, and I'm not an isolated case.
My choice of tips is quite limited with huge ear canals, so proprietary tips are a complete no-go.
Hi everyone
Could anybody with having the expreince of testing both ie80 and ie800 help me as i'm considering an upgrade from my ie80 which i found the bass leaks too much in mids and make it an inappropiate match for metal and rock
Unfortunatly i live in iran where there is no turning back policies and not much options to choose from and these things are stupidly expensive due to our low currency ratio so there is no room for making mistakes when you're purchasing an item
I'd appreciate if some one gives me a deep comparison between these to
Ps : i should excuse if i'm making any mistakes in my writting as i'm not much familiar to English as you guys
Thanks in advance
@Dobrescu George
That was an awesome review and so helpful i really enjoyed reading it
But to be 100% sure would you mind to compare ie800 with ie80 in term of isolation and bass bleedage to lower mids in a scale of 1 to 10?
I know you'v already covered every aspects in your review but as i'm paying a large amount of cash on these and i'm not satisfied with uncontroled bass and sharp trebles of ie80 and not able to audition these befor purchasing it's a really big deal to me to be completely reliefed by these facts as many others head-fiers considered ie800 a bass heavy harshed treble iem
It would be very kind of you to declare the issue once and ever for me
@james444
Thanks james so there will be no more muddy sounds listening to metal and rock acording to what you're saying?
I'm not treble sensitive but in some few songs i feel the treble is too agresive on ie80 specially with edm or house not an issue with most songs
So how about the clarity ? Is it a huge improve from ie80s?
I know i'm asking too much questions and i'm really greatful for your patience but also could anyonesuggest which dac/amp or player will best fit ie800s?
My options are listed below :
1-chord mojo+iphone6s
2-oppo ha2+iphone6s
3-Ak70
4-ak300
And no needto mentioned i dont want the dac to add to the almost on the edge bass
@Dobrescu George
