james444
- Aug 25, 2004
Thanks Tyll, I thought it wouldn't be easy to explain. What draws my attention is that both channels are actually very well matched from deepest bass up until 7kHz, so the cause can't be leakage, because that would show in differing bass levels. "Incidentally" 7kHz is exactly the frequency where the IE800's dual chamber absorbers (D2CA) kick in, and now we suddenly see a difference of up to 20dB between left and right channel, extending upwards until past 10kHz.
My humble guess is that D2CA failed to work properly in the left earpiece, either due to a manufacturing defect or a fit related (probably insertion depth) issue. The right earpiece, however, is in my understanding quite linear in said frequency range and not sibilant at all.
The best explanation I can give you is that the IE800 is VERY difficult to measure. For whatever reason, they just don't like being inserted into my measurement head.
Sorry, bums me out. Just don't know what to think.
So, there is a remote chance the IE800s are not 'officially' sibilant? Hurray!
