m00hk00h
- Feb 23, 2006
Then it was you who got them. I did also bid for them but they got just too expensive for me. I was just looking for a pair that could serve as a "part donator" for my beloved Jubilee.
I later got a second one from a fellow head-fier for a very good price but without certificate and stuff. So perfect for my needs.
I do indeed agree with much of your reciew which is -btw- very nicely written. The "hollowness" and "veil" are caused (imho) by a slightly recessed presence range. This can be found on every 580/6X0 and for me as a main DT880 user it's really disturbing (the DT880 has a small emphasis in the presence range). Also I thinks the highs of the Jubilees are a bit "artificial". I alway found the hoghs on the Senns as kind of not belonging to the music but floating a bit over it. Strange and hard to express. I for mayself think that the DT880 has much better (and smoother) transition from low end to top end without any breaks in it.
I also had the chance of A/B listening to different HD600s with my Jubilee(s). And the difference is hardly audible and only when A/Bing. They are very very close.
But in fact not even the Jubilees sound the same so I guess the differences betwen HD600 and the Jubilee is simply caused by the matched drivers. I am sure you will find a HD600 that you can't tell apart from a Jubilee.
Please don't see that as an advertising for the Beyer...it's for explanation reasons to follow my expressions because I simply know the DT880s so well.
@skyline889:
Does the foil come off from the front and the back side of your headband? I mean: are there any fine fissures in the foil caused by the tension of bending the headband?
I got myself a new headband from Sennheiser (one of the last) but I only put it on once and directly after these small fissures appeared.
Really annoys me.
And do you have other grills? They look dark on your pics. Mine just look more "greyish"!?
To all:
Maybe you enjoy some more pics?
![](http://mitglied.lycos.de/tschnutschi/rest/cans/sennheiser/hd580jubilees2_klein.jpg)
Click to enlarge!
w/o flash
w/ flash
![](http://mitglied.lycos.de/tschnutschi/rest/cans/hd580jubilee_w1000.gif)
Click to enlarge!
Oh and: I have taken the foams out, too. But I put the foam between the outer grills and the backside of the drivers. This tightens the bass and locks just awsome!
w/o foams w/ and w/o flash:
w/ foam
I think it's closer to "what it's supposed to look":
m00h
Originally Posted by skyline889 /img/forum/go_quote.gif Thanks for the compliment Blackmore! I unfortunately got into a bid war last year over this pair but typically, I've seen good condition pairs range between $180-250. |
![wink.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/wink.gif)
@skyline889:
Really annoys me.
![mad.gif](http://www.head-fi.org/forums/images/smilies/mad.gif)
To all:
Click to enlarge!
![pattern1.jpg](http://mitglied.lycos.de/tschnutschi/rest/cans/sennheiser/pattern1.jpg)
w/o flash
![pattern2.jpg](http://mitglied.lycos.de/tschnutschi/rest/cans/sennheiser/pattern2.jpg)
w/ flash
Click to enlarge!
![ohne_ob.jpg](http://mitglied.lycos.de/tschnutschi/rest/cans/hd580/ohne_ob.jpg)
![ohne_mb.jpg](http://mitglied.lycos.de/tschnutschi/rest/cans/hd580/ohne_mb.jpg)
w/ foam
![mit.jpg](http://mitglied.lycos.de/tschnutschi/rest/cans/hd580/mit.jpg)
![packung.jpg](http://mitglied.lycos.de/tschnutschi/rest/cans/hd580/packung.jpg)
m00h
