Drat, unable to update my QP1R, and I was one of the lucky ones who never had a problem before.
Downloaded file from Questyle China
Formatted a 2GB card that worked before with my QP1R
Drag and drop v1.0.8 download, unzip file and trash RAR file just leaving v1.0.8 file on card (has Chinese writing too). Done on my MAC.
Getting "update file not found" message on QP1R.
I tried lots of variations and even my old standby PC but no joy. Any idea what I'm doing wrong this time?
Is it the q1.fw file that you are leaving? Also, I think the card needs to be in slot 1 IIRC.
I also might try formatting the card in the unit not in the computer.
Here sthe section on updating form Moe's review (from the first page of this thread)
"(Q31)
How to update the QP1R
The QP1R can be updated via software update that is placed on a micro SDXC card.
You can go to
http://www.questyleaudio.com/download (click the "Drive" tab) to download the latest firmware.
Here are the directions that are located, verbatim, in the “About QP1R” screen in “System Settings”:
How to upgrade:
1. Copy file QP1.FW to QP1 TF1 flash slot.
2. start the machine, select the” system settings - firmware upgrade - yes “.
3. After upgrade,the display will show “Upgrade finished” and restart the player.
I recently updated to the newest firmware version, and the file given to me is called “q1.fw”. I made sure to turn off the QP1R, use a formatted blank micro SDXC card to copy the file to (I used the QP1R to format my blank Samsung EVO micro SDXC card), then turned on the QP1R and updated via “System Settings”, which took less than 30 seconds.
Make sure to place the "q1.fw" file in the TF1 (first/left) flash card slot to update the firmware, not the internal storage!
Update process - Updating, Updating after around 15 seconds, Update success"
