Has anyone contacted bSquared64 to find out what the fix is, as he requested you to do if you were still having battery indicator issues?
If so, what was the fix?
So was it sent back because of the battery indicator fault?
So everyone with a QP1R is going to have their unit sent back to Japan for a hardware fix if they want an accurate battery indicator?
I wanted to share my experience till now with the device in around 1 month usage.
I like the player, i faced lots of problems it seems to be concerning ram and space under heavy usage but i think under normal usage there will be no issues, so not a deal breaker for me..
Since i got it first thing i updated the firmware and the battery has been working in a good manner, dont know if mine skipped the battery problems or it takes some time to happen ..
I use 400 gb card, with a bit more than 20000 files, the library is updated with only the limit, when i try to open a playlist containing large number of files, it takes long time and eventually gives a blue screen of death, so i stopped doing this.
Also when i keep going manually through folders and play songs sometimes all the folders appear under one name and they are all empty then i have to restart ..
Also, when i use it in shuffle ( my normal way to go ) with any song numbered in the library above 12000 fast forward and rewind doesnt work.
I think all these are ram problems or how ram is handled by software and may be the reason why they dont want to increase the file limit.
Other than that i use it under shuffle, when iam craving some song, i seek it by browsing and iam liking what i hear.
