moedawg140
Grand Master Moe "G"….Don't crossface me, bro!
Ping Pong Champ: SF Meet (2016,2017), CanJams (London 2016, RMAF 2016, NYC 2017, SoCal 2017, RMAF 2017)
I have confirmed the QP1R USB DAC to work with the iPhone 6. I've got experience doing this when I hooked up the DACport Slim, DACport HD and Grace m9XX the same way for their respective reviews, so it's great that the same items used to connect to those DAC/amps works the same way with regards to connecting the QP1R.
In order to not see the "The connected device requires too much power." message on the iPhone, you need to make sure there is a power "handshake". What that means is you will need a few items in order to make the QP1R's USB DAC function correctly in conjunction with the iPhone (6 in my specific case). The items are:
-A power source that has USB-A input (most all do, like a USB outlet adapter or a external battery charger)
-A USB-A to USB-A cable (male to male)
-A multi-USB-A port Hub
-A micro USB cable
-An Apple CCK (camera connection kit) cable
Here is the chain to make the "handshake" work:
Use a power source that has USB power or an external charger and connect the USB-A cable to it.
Connect the other end of the USB-A cable to a USB Hub port.
Connect a micro USB cable from the QP1R to a free USB Hub port.
Connect the male USB connecting cable from the USB Hub to the Apple CCK cable port.
Connect the Apple CCK Lightning connector to the iPhone 6.
Connect your favorite C/IEM or headphone to the QP1R and play your music through the iPhone 6.
Troubleshooting:
In case you see the "The connected device requires too much power." message on the iPhone, make sure the power source (outlet and/or external adapter) is turned on and that all cables are seated snugly in their correct locations in the USB hub and devices.
Make sure that "DAC" is set in "System Settings" > "USB settings".
I will add these steps and more information in an update in the QP1R review (first post of this thread) in the near future.
Take care!
-A micro USB cable
Troubleshooting:
Take care!
