kino lau
- Sep 18, 2014
It's becoming increasingly difficult for me to not pull the trigger on a QP1R. I've had it right at the payment screen just about every night, for the past week and a half...
Been there too...I delay the inevitable by saying i should sell something first to help pay for the new toy!!!
But i end up giving in most of the time.
Got mine on Thursday. Sounds beautiful and clear right out of the box. Can't wait around for burnin, so I'll just burn in with it and enjoy developments as they come. 1st album was GauchoDSD; mouth open.
One little thing, Moedawg. No big deal, but I found a little EQ.ini 1kb file in the onboard storage. Is it needed for anything or can I just get rid of it?
Thanks.
Thanks.
The internal storage is protected, it is allright to delete the files you see when connected to a computer (this may be different if you are operating under Linux, I'll check that tomorrow), IE: if you select all and delete to clear out the music files, it won't hurt the player, the necessary files will regenerate when you reuse those functions. On the other hand, your EQ settings will reset to default, as will the play lists, favorites and the music libraries.
I feel that the qp1r wins ak380 in terms of Sq. Way more power and very solid details. Feel like getting one too. Tested with fitear mh 334 and 435.I hope that there could be touch screen too.
Yeah...if there was an available Dignis leather case (or any decent case, really), there would already be a new charge for $899 on my credit card statement. OH...AND the price of the case...lol
Hey ... I just joined ... I'm thinking about getting a new pair of headphones to specifally use with the QP1R ... currently I have Westone 50 UM pro's, Beyerdynamic DT-1350 & AKG K-702's .... I've always wanted to try/get a pair of Grado's (especially since I am from Brooklyn where they are based).
I was wondering if anyone had a recommendation as to which model to focus on or maybe a different brand? I usually just listen to Rock and Blues music and I like things a little on the bass side ... cost it not an issue but I think no more than 1500 is what I want to spend ... also would prefer closed back so I can use them in the office but that is not really important just a a side factor ...I know the Grado's are open
I've been reading through a bunch of reviews on headphones and frankly my head is spinning from everything
Thanks for the answer. I don't use EQ as a preference, but I'll leave it alone.
I know I was griping about the user manual being released as a .pdf, but I have to once again, complement Moedawg for his review sections Q25-35. He explains things so well that even a blind dude can use it.
And kudos for the tactile response feature.
You know it can be bad for system resources to leave tabs open with info sitting in a form like that. As an IT professional, I advise that you complete the transaction. Not only will it improve your PC's performance, but your life as well.
You will give in. Search your wallet, you know it to be true.
The AK DAPs have an awesome UI, and this holds true of the AK380. I find it easier to find specific songs on the 380 than on my QP1R. But sound takes priority, and the QP1R's UI isn't difficult to use. For me the QP1R is the winner, and a savings of $2600 is just icing on the cake.
Here's a question that kind of explains my hesitance to buy into another DAP "just because." Anytime that I use my IEM's to listen to music, it's with my X5/E12A combined. I don't care about the small brick because I'm always sitting or lying down. So the question is...apples to apples, QP1R vs X5 is one thing. What about apples to oranges, QP1R vs X5/E12A? I'm more concerned with SQ than I am with absolute power, since obviously I have no current power issues.
From what I was told at the show by Gary (awesome guy btw) was that the QP1R would not need an additional portable amp because it has the power to run high powered IEMs and Headphones. this should be factored in when you think about pricing because a lot of DAPs actually need an amp to use higher end gear. I hope this helps clear things up.
