goodvibes
- Dec 28, 2009
Here you go.
Jumped output resistor. Underneath because I just used the lead from where I added the bypass cap:
Here's the top with those added caps and replaced input caps plus the strain reliefs. I prefer this to just running the wires through the hole as any movement can break a wire joint in time.:
Here it is ready for a dual battery try. Moved the black lead over a spot to true ground and attached the other side across the neg phase of the supply. The resistors across the batteries shouldn't hurt performance and will stay for now. The on/off switch would need to be reworked and resistors removed if it was to be used this way:
Haven't listen yet with the stiffer 2 battery config. My batteries aren't with me.
