ZapX629
- Dec 28, 2013
Yeah, if you can stretch it to $250, the CKR10 seem like they'd be the perfect fit.
I'm not looking for more bass, I would like to get another model that does not lack bass. For instance I had the SE215 and to me that lacked bass at least to me.
Coming from TDK BA200 . Also owned the TF10 and the Klipsh X10.
Out of these 3, I prefer the BA200 the most . ( neutral , good enough bass, comfortable )
TF10 is too V shaped and most lousy fitting.
X10 the bass is superb. BA200 to me the most all rounder.
I'm looking at something that can be powered easily by my iPhone 5s and I would like to get something that has more drivers than my existing line of IEMs. Which one is an upgrade to me?
Thanks.
Sounds like you'd want the IM03.
I haven't tried the CKR10, so I can't comment on that. I wouldn't recommend the CKR9 though, it's a fairly shrill and analytical IEM, and it doesn't hit very hard. If you're looking for something for Hip Hop and the likes, I think you'll be happy with the Sennheiser IE80. It has a dial that lets you adjust the amount of bass. Even at medium settings, it's quite powerful. It doesn't have the same clarity as the CKR9, but the sound stage is wide and the overall profile is buttery smooth.
What about the IM04? More drivers = better? Hehe
Has anyone compared the IM50 to the Vsonic VSD3S before? If so, what's the verdict? (Sorry for being late to the party!)
I don't have the IM50, but I do own a IM70 and VSD3S, and the former is leaps and bounds ahead in build quality. The build of the IM50 is essentially the same, so I assume that would be the case with that IEM as well.
Oh, that's good to hear. How about the sound quality, the more important part?
VSD3S is V shaped While IM50 is U shaped as Zap said. When you switch from IM50 to VSD3S, you will immediately notice that the vocals are muted and some kind of veiled on VSD3S and the treble being shrill.
VSD3S is clearer and has a much more sizzly treble which can sound artificial. The VSD3S is maybe a tad more spacious, but not by much. IM50 has much nicer mids and a fuller, warmer bass. Treble is smoother by a mile. As said above build goes easily to IM50. I think that overall, they're right neck and neck with each other depending on what you like. If you want a more U-shaped sound with bright treble, you'd like the 3S. If you like a bassier, mid-centric sound with a smooth treble, you'll like the IM50.
Interesting. Thanks for that. Would you guys say that it would be worth having both to complement each other?
And also, ozkan, did you say that the VSD3S would sound more veiled as opposed to the IM50? Because if the VSD3S is supposedly veiled-sounding, then I think I'm going to enjoy the clarity that the IM50 would bring to the table.
