julabask
- Jun 17, 2009
i find it funny you say the pro4aa were horrible and the way you describe it being bad while they are known and from experience one of the only good headphones koss makes lol. the fact you say every thing sounds dull thin or muddy makes me think you dont know to much about headphones. there specs on the box are right and they are great i just think you missed the fact they are low sensitivity and 250 ohms. meaning you need an amp for them to sound good lol. do you use an amp with them probably not. otherwise they will sound just like how you said. obviously if you new much you would have known that. you should not say things about headphones that you dont know much about. those are great ones. probably used your weak computer to power them or something like a mp3 player does not work. the pro3aa sounded better because it does not need an amp its 60 ohms. learn more about headphones before giving advice. though your right those ktxpro are okay for the price. the sennheiser px100 destroy them though. and the pro4aa with an amp slaughters all of them. that were talking about. buy an amp then use your pro4aa that are sitting in your closet and then give a review about those then you will know some real hifi sound. lol. i cant believe you bought those and did not know you needed an amp and thought they sucked because you were just underpowering them the whole time.
