Assorted
- Jan 21, 2007
Amps will always help if you're running high impedance headphones, especially using this method: http://www.head-fi.org/forums/showth...=preamp+hornet
The GB9 doesn't work with WMP unless you use the new firmware (which I don't). And I don't understand the first part of what you said :/
Originally Posted by chiaping /img/forum/go_quote.gif correct me if i am wrong, this player has pre amp and amp inside? so does that means external amp are no longer needed? will it help the sound quality to use external amp such RSA ? can't wait for ur reviews thanks |
Originally Posted by Aevum /img/forum/go_quote.gif how is it in the "jump trough hoops to load music" department ? it brings a normal USB or propietary connector ? do you have to sync it with WMP or Kenwood's own Music administration software or can you just drag and drop music in to it ? |
