In case anyone's interested, I'll post my translation of the official site (from a part of my review). I'm still waiting on a couple of things
[ Clear Digital Amp EX ]
The digital amp chip is compounded into separate pre-amplifier and power amplifier stages, thus allowing a clear, high resolution audio playback.
The pre-amp section utilizes a high speed 32 fs over-sampling converter that significantly reduces noise floor. The power-amp section uses proprietary Kenwood Clear Digital current which minimizes the THD.
A breakdown of the graph: Digital signal > PRE AMPLIFIER: [32 fs over-sampling ΔΣ + PWM converter digital amp] = [low ripple current] > POWER AMPLIFIER: [digital amp] = [switching controller, sensing amp, driver] > LPF > Analogue signal
[ Supreme EX ]
Lossy audio formats such as MP3 and WMA often loose audio data beyond 16 kHz. As a result, the depth and quality of the sound is lost. The original Kenwood Supreme EX technology preserves audio data beyond 16 kHz using independent algorithm. Wav or other lossless files now sound like a live performance in front of you.
[ Kenwood Lossless ]
The Kenwood original Kenwood Lossless codec allows you to maximize storage by compressing lossless files to 60% (on average) of its original size while maintaining the lossless sound quality.
* f-Hole Grand Chassis
The “f-hole” implemented in the light and highly durable non-magnetic stainless alloy chassis brings desirable vibration that brings a clear, in-depth sound.
* High Quality Materials
The coil uses a chip inductor that shields it from unwanted magnetic interference. The mid-high range is emphasized, bringing forth a very musical sound signature.
* Digital 5-band Graphic Equalizer
The digital amp allows a highly resolute 5-band graphic equalizer. The unit stores up to three user-defined settings, and includes 8 presets according to different genres.
* User Friendly Interface
Flip through different menus at the touch of a button. The layout is designed to simulate a cell phone like layout.
* 2 Way Speed Search Key
The bi-directional seek buttons allow a slow seek mode with a light press, and a fast seek mode with a harder press.
* GUI (Graphic User Interface)
A 2.2 inch QVGA color LCD display displays an aesthetically beautiful interface.
* Support for Kenwood Lossless / MP3 / WMA (DRM) / WAV Playback
* Alarm Timer / Sleep Function
* Chargeable from the USB Bus / Playback while Charging (AC adaptor is available at Kenwood Shop)
