- Jan 30, 2011
Hey Rocky, Could you also make the nozzle a little smaller in diameter?
Please no - otherwise it would change the sound sig - and none of the standard sized tips would fit any more ......
Hi Brooko,
I owned FA DBA02-MKII and it has a very good detail, good sound stage and separation. However i found the treble is slightly bright (ear fatigue) and the bass is not punchy and deep.
May I know if Dunu DN1000 has punchy and deep bass and smoother treble with similar detail, sound stage and separation like in DBA02-MKII?
Been a long time since I heard GR07 (MK2), though I can safely say DN-1000 is stronger in soundstage and instrument separation, tonality of DN-1000 cooler showing more clarity. I know GR07 is popular and won a ton of fans remaining the most balanced however I don't feel it's on the same level as DN-1000 personally overall.
I think those who come from GR07 may possibly find DN-1000 sounding a touch thinner or lighter in the mid range but superior in detailing levels. I really did like GR07 MK2 enough to own x2 pairs but I thought H-200 was an upgrade to the Vsonics and consider DN-1000 an upgrade from H-200 if that means anything to anyone, so not really the same playing field for GR07.
now i want a pair to replace my h200 that I still have but never really started liking :|
It might be worth your while selling those H-200 and giving the Dunu a try.
ordered a pair. keeping the h200 since have no other cheap(er) earphones for the time being
