So... the Schiit Fulla 2. How does it
stack up?
It stacks pretty well.
But seriously now, how does it compare to the DACport?
Well I can tell you that there's a noise floor on the Fulla 2 when nothing is playing. It is, however, slightly lower than the DACport Slim/HD's noise floor. Maybe 1/3 less. But it comes through without a doubt on my KZ ZS3.
The lowest pot setting on the Fulla 2 also puts out a low volume of music through the headphone out. You need to have really efficient cans or IEMs though to hear this. I couldn't hear it with my T50RP or HD 6XX.
The channel imbalance on my Fulla 2 is pretty bad. By the time both channels were balanced on both my T50RP and HD 6XX(both considered power hungry cans!!), it was above my preferred listening level(8-8:30 on the Fulla 2). My particular unit has the left channel increasing in volume a lot faster than the right channel. Of course, put on my KZ ZS3(efficient @ 18ohms) and it's enhanced even more. Very disappointing, getting a pot this bad. It's so bad that I'm considering asking schiit for a replacement.
Fulla 2's headphone out also seems to be susceptible to some sort of RF. I had a kindle w/ Wifi on as well my phone in relatively close proximity to the Fulla 2 and there were some audible ticks. Turned both off and it went away.
Fulla 2 gets a little warm. But if you've had the DACport Slim on a hot day, the Fulla 2 is nothing when it comes to heat output.
Sound? Well it's only been an hour or two at most so I need more time to form an opinion. But I think the DACport Slim sounds a bit fuller. The Fulla 2 seems every so slightly more thin. Needs more testing. Which I am not looking forward since the channel imbalance is a pita.
Oh yeah, the DACports are also so much smaller.
If you showed me a DACport Slim and a Fulla 2 as my only two options and told me to pick one, it would be the DACport Slim at the moment.
