DangerClose
- Feb 26, 2013
Distorted bass is easy to come by. Well-articulated and textured bass, not so much. If it's all about the rumble, you may want to opt for different headphones.
It's not all about the rumble. It's more about a small subwoofer not being an oxymoron.
Anyway, I went full bass mod again recently on my Q701. I can tell it helped a lot in the fun department because I no longer noticed the headband digging into my head.
I just read that the outside cover removal and going in with pliers can work.
They'd have to be small-ended pliers. Whether grabbing it with pliers, tweezers, or something else, you might have to use a pointy knife to get it started and to pry on it. The adhesive can be strong.
The main concern is probably when taking the plastic cap off on the cable side, (of the Q701 anyway), since the plug wires are in there, and they are thin and short, and there's a chance someone doing the bass mod might wind up becoming an expert on soldering AKG wires.
