Hi all --
The battery in my Headamp Pico DAC/Amp seems to be on its last legs. It doesn't hold the charge for very long -- I'll be lucky to get a couple hours out of it. I tried contacting Justin at Headamp, and aside from an initial diagnosis, after repeated attempts, he has been unresponsive to arranging service to replace the battery.
I am going to attempt to replace the battery myself.
In this thread, oOKaMiZuKOo successfully replaced his battery, although I don't think he sourced the correct battery.
https://www.head-fi.org/threads/headamp-pico-how-to-change-the-battery-where-and-what-to-buy.810801/
I can verify that the original battery is a LiPo, and is labeled GBP443440. Looking up this battery, I believe this is a 3.7V. However, it looks like there are 2 cells here. When I check with a multimeter, the voltage is 7.8V.
So it looks like I will need a 2S pack, however, I am having a hard time finding a battery like this (7.4 V, 9 x 34 x 40 mm, with 3 leads). Can anybody help with locating a battery, or alternatively, how would I go about taking 2 x 3.7 V batteries and wiring them in series?
Thanks in advance!
Ted
Thanks in advance!
Ted
