sdcmunich
- Dec 29, 2010
I am looking for a replacement for my Philips SHE9500, but this is the second time I lose the left side because of a cable problem at the neck split, so it is time for a change.
Even though the sound was quite OK to me.
I am mostly listening to jazz, I don't like very strong bass.
This is mostly for using during commutes, so durability (especially cables) is important and good isolation would be a nice plus.
After doing some research, it looks like if I stay in the same price range, the Klipsch Image X1 (25 €) or the Sennheiser CX 300 II (35 €) could be good candidates. The Klipsch doesn't look very sturdy, though, and I read that the CX 300 has strong bass, not mentioning this issue with the fakes.
Other companies such as Denon or Sony are around the same price, but I can't find any review of their headphones.
Would you have some tips in that price range? How would the SHE9500 rate compared to these headsets, by the way?
I might also consider more expensive headsets, such as the Etymotic MC5 (70 €) or Shure SE115 (75 €), but only if the difference in sound quality/sturdiness makes it worth spending double the money.
Thanks for your feedback!
