Recording Impulse Responses for Speaker Virtualization
post-15919586
Post #436 of 448
musicreo
Reactions: halcyon
post-15921016
Post #437 of 448
johnn29
Absent of any reflections the center channel would actually be pretty hard to locate.
Been happily using Impulcifer for months now. Risen to 50% of my viewing/listening. Next door house is a construction site and my cellar below me is having to have industrial extraction fan to cope with the humidity due to some construction there too. A crap show for watching high dynamic range movies - noisy as hell.
Bose 700 ANC on, Impulcifer processing - silent bliss. Can't get over it.
Reactions: halcyon
post-15921187
Post #438 of 448
halcyon
Interesting. In real life, with natural sound sources (without visual cues) this is fairly easy.
Then again, IRL again, the right behind sound direction can be somewhat confusing (without head movement). But tons more accurate than any of the Virtual Sound Processing algos are able to achieve.
IMHO, almost all of the Virtual Surround Processing algos fail abysmally with behind the listener sound localization.
Then again, in my own experience even inside a completely dead full size anechoic chamber, this cone cone of confusion is comparatively smaller again IRL (compared to Virtual Surround).
Why are the virtualization algos not able to achieve the same level of sound source localization for behind the listener sources? Is it all down to (lack of) head movement?
post-15923266
Post #439 of 448
musicreo
How is the mic calibration (left-mic-calibration.csv/right-mic-calibration.csv) processed into the final result? So far I don't hear difference?
post-15924488
Post #440 of 448
jaakkopasanen
Helsinki, Finland
Helsinki, Finland
Mic calibration is not supported. There's only calibration for a single room measurement mic. That's baked into the impulse responses by eq when doing room correction.
post-15924685
Post #441 of 448
jaakkopasanen
Helsinki, Finland
Helsinki, Finland
The localization perception is very much an individual thing. I fail to get frontal localization with all virtual surround systems except when the BRIR is my own. I think the majority leans towards front localization being harder than rear localization but I have no data to back this up. Virtual surround with headphones have other perceptual challenges as well because when you wear headphones you are aware of it and even the perfect matching BRIR can be confusing when you consciously know that you're listening to headphones. Another problem is the potential mismatch between room acoustics of the BRIR and the room you're listening in.
Reactions: halcyon
post-15933761
Post #443 of 448
outerspace
Russia
Russia
Sit on chair, close your eyes and ask someone to snap fingers in 0.1-1 m distance around you. Try to point out were sound is come from. You will realize you not such precise as you think if eyes are closed. You can confuse sound from front with from back and vice versa. Such experiment you can see here.
post-15934031
Post #444 of 448
johnn29
pfzar thanks for posting those papers.
The brain uses multiple senses to get an idea where a sound is coming from. In nature i've noticed that head tilting is important. But in small rooms it isn't. If you look at a dog trying to locate a sound - that's an extreme example of what we do.
post-15937734
Post #445 of 448
yosoro
china
china
Traceback (most recent call last):
File "recorder.py", line 260, in <module>
play_and_record(**create_cli())
File "recorder.py", line 206, in play_and_record
min_channels=n_channels
File "recorder.py", line 135, in get_devices
devices = sd.query_devices()
File "C:\Users\17810\Impulcifer\venv\lib\site-packages\sounddevice.py", line 565, in query_devices
for i in range(_check(_lib.Pa_GetDeviceCount())))
File "C:\Users\17810\Impulcifer\venv\lib\site-packages\sounddevice.py", line 565, in <genexpr>
File "C:\Users\17810\Impulcifer\venv\lib\site-packages\sounddevice.py", line 578, in query_devices
name = name_bytes.decode('utf-8')
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xc2 in position 6: invalid continuation byte
Occurs when running recorder
post-15937738
Post #446 of 448
jaakkopasanen
Helsinki, Finland
Helsinki, Finland
Could you share the full command you used?
post-15937739
Post #447 of 448
yosoro
china
china
python records.py --play =“ data / sweep-seg-FL,FR-stereo-6.15s-48000Hz-32bit-2.93Hz-24000Hz.wav” --record =“ data / my_hrir / headphones.wav”
post-15937748
Post #448 of 448
jaakkopasanen
Helsinki, Finland
Helsinki, Finland
