I've been doing lots of experimenting with virtual room correction and I like my results now combined with the experimental reverb management feature.
My real room has a ton of ringing in the low bass. I have rigid walls and floors, the benefit is crazy room gain (115db to 6hz on a small sealed sub -SB2000) but I get ringing.
RT60
See the above plot - that was only at 75db, the louder the worse the situation is. Bass response after real EQ is fairly flat, so multisub in the real room won't do anything to get rid of ringing from my understanding. See below (no smoothing):
All it can do is destructively interfere with the peak and kill it to flatten response. Still rings, but less peak. Besdies, that's another £~800ish, a ton of setup and pain etc.
To really get rid of it it'd take bass traps - which is a big project and will eat up room and I cannot be bothered.
Enter Impulcifer. I nailed a nice virtual room correction on top of what Audssey did up to 250hz. It killed some of the peaks I had in the midbass which you can hear on A vs B. But the ringing still remained. I get this weird sensation in my ears when I hear it too, not sure if it's some weird phasing thing but it definitely sounds jarring in my real room. A testament to the convolution method is I get a similar feeling with the headphones.
So I used the reverb management from the experiments folder to set everything to 300ms. No more ringing! I guess this is time domain management we can do in virtual rooms which are impossible in real world. What's interesting about the reverb control is when you take it to artificially low levels, like sub 200ms the bass perception is much lower. I guess the SPL is identical but tighter/dryer so it's perceived as less?
Jaakko - is it worth trying to roll this into the room targets for virtual room correction? i.e. an ideal decay time?
Thought it was worth sharing - an example of how you can improve on your real rooms with this stuff. Still blows my mind. And it's better than the Smyth - you cannot do any of this with the A16.
