"Sufficient bass"? I always thought the MS1 was a fairly warm headphone, you aren't likely to change it from what it is. Are you already using flat pads?
Originally Posted by FallenAngel /img/forum/go_quote.gif "Sufficient bass"? I always thought the MS1 was a fairly warm headphone, you aren't likely to change it from what it is. Are you already using flat pads?
Originally Posted by dikyllis /img/forum/go_quote.gif Uhmm put it this way, I want it warmer
Ok, put it this way - you're better off buying different headphones, but if you are really set on the MS1, use the comfy pads and maybe go with Cardas 4x24 ($5.75/ft from Percy Audio)
Replacing the cable isn't going to change the nature of the headphones. If the MS1s are too bright for you, you're going to be better served by selling them and getting different headphones.
