QuantumXL
- Nov 18, 2010
Well of course there are certain situation. The reason why angled is so much better for me is because it tends to last longer. The more flexible cable would break down faster and lose signal. When you have to send your IEMs within the first month and again 3 months later and again 7 months later it gets frustrating. All of which contained a right angle tip. It wasn't until they revised it that I can actually get past the first month without a break is good to me. The thicker and higher durability is better than the fragile connector (just a personal preference). This may be due to the storing into the headphone case but I don't see why that should be a problem?
The old cable was a right angle tip, but it was thick, stiff, and held memory. Then the revised it to a little thinner, lighter, more flexible cable with a straight tip. Frankly I don't mind the cable. I'm not really sure why people whine so much about straight vs angle. I think it becomes somewhat dependent on what the earphone's hooked up to. In some cases you want a straight cable, some an angled one.
