VintageFlanker
Is there any way to bring the ES100 to EU?...
A2DP is a profile for any music. Aptx is one of the compression codecs that can be used with A2DP. What do you actually want to ask?With filmware updates was introduced support of a2dp codecs. Does any one know how it performs compare to aptx?
Your phone is most probably supports AAC which sounds better than APTX.I meant to say , Is there going to be a noticeable downgrade in sound quality if my phone doesn't support aptx only a2dp?
Ah?... I would say the exact opposite as well as many reviewers... Aptx supporting up to 350 kb/s (up to 24b, 576kps with aptx HD) while ACC is 256 kb/s. So you can stream ACC files without compression or resampling... But as far I'm concerned, I don't use mp3/AAC files, so Aptx HD still the way to go.Your phone is most probably supports AAC which sounds better than APTX.
I'm confident that on blind tests most will say that aptx is brighter and dirtier sounding codec. As for the technical quality - it's significantly worse. AAC is much more fine grained 20 years old psychoacoustic codec improved over mp3 while aptx is 45 years old ADPCM and nothing more. APTX immediately brings high frequency noise that some people like since it works as a very rough few dB EQ for free. AAC achieves ITU transparency at 128kbit.Ah?... I would say the exact opposite as well as many reviewers... Aptx supporting up to 350 kb/s (up to 24b, 576kps with aptx HD) while ACC is 256 kb/s. So you can stream ACC files without compression or resampling... But as far I'm concerned, I don't use mp3/AAC files, so Aptx HD still the way to go.
Ok, so I might have to tweak the EQ or do some mod, to get the same type of sound then.Based on my tests with significant load - earstudio stays relatively flat until roll off point.
The app has a very decent EQ with presets and 4 custom saved levels.Ok, so I might have to tweak the EQ or do some mod, to get the same type of sound then.
I was really looking at the Get before the ES100 but for a variety of reasons I chose to take a chance on the ES100 and have been more than satisfied. A big part of the reason I went with the ES100 was the support that WSLee has provided here on the forums. I mean I asked about the battery level indicator on the iPhone and it was addressed in a FW update a few days later lol.
Also, I liked the battery life on the ES100 as well as the option for a balanced output.
