- Jul 30, 2015
Anyone else have a solve for when the iOS app doesn't recognize the ES100 is on even when it is? I can't access the EQ, or other audio settings through the app anymore...
What headphones are you using with the ES100? I use mine with PC USB connection most of the time and have never heard any hiss. It might be the quality of the usb hub it's connected to. If you can, try using it with a different computer to see if the hiss is at the same volume.Testing on PC as a USB DAC/amp, soundstage is larger and signature is little more substantial, but there's an audible background hiss while the amp is on before it cuts out after about 10 seconds, and I don't know what settings the ES100 uses on PC besides the sample and bit rate inputted at 16-bit/48khz, 24-bit/48khz outputted, unless most of the app settings save to USB as well?
Sennheiser HD 598 Cs.What headphones are you using with the ES100? I use mine with PC USB connection most of the time and have never heard any hiss. It might be the quality of the usb hub it's connected to. If you can, try using it with a different computer to see if the hiss is at the same volume.
Also, all the app settings do save when using it on a PC. You can still change them with the app while playing from PC as well.
Hey guys are there any companies making clips for these to be used on headphones?
You can velcro it to a headphone. I've done this with 2 different headphones with a very short cable and it works well.
Nvm, still a problem.Seems as though the hissing/background noise when using via PC quieted down when the bluetooth connection is disabled between the ES100 and phone.
Seems as though the hissing/background noise when using via PC quieted down when the bluetooth connection is disabled between the ES100 and phone. The problem I'm having is the volume is rather low and limited on PC, like it doesn't want to push further when the volume sliders go up, and it's hard to know what the device is doing, and how it's performing without using the app. I'm not sure if the PC volume controls the analog or source, or both, or if the app needs to be used to max out the analog volume to a proper level before using the system volume, and adjusted to what's considered "enough" for PC. I have the device set at -3db which is plenty loud on phone, so I'm not sure if the PC demands more in order to use the system and player volumes correctly because they can be almost maxed out, and the ES100 still sounds like it can't go further. I have the system volume set to 100%, but the player volumes in browsers and apps make less of a difference when increasing.
If you play a video or song and mute the volume, you may be able to see what I'm talking about.I've used as a USB DAC with a PC and never really noticed alot of hissing or lack of volume. I usually set the app and PC system volumes to 100% and control the volume with the ES100. I do the same when using the ES100 as a bluetooth receiver (which is the way I usually use it). Not sure if that is what you were trying to ask.
I also use easy to drive headphones and IEMs.
