AmusedToD
- Jan 1, 2017
Ah okay, that's fair enough. Just wondered, glad you got it sorted.
That's what this community is for, isn't it (among other things)
I had no issues with it at all. Updated cleanly and connected swiftly to my phone.
Spent a good amount of time today doing back to backs between BTR3 & ES100 .... now i've got things settled i really am struggling to discern between them in terms of SQ
Only difference really is the fact that on the ES100 i feel i have to use the EQ a little whereas the BTR3 doesn't have EQ (not yet but coming according to the app) but it does sound the way i like so not sure i'd use it anyway
Try support@radsone.com . I used this address to communicate with them when I needed my unit replaced. It took them a while, and I really had to keep bugging them, but eventually I got a replacement. Good luck.Does anyone know how to submit a warranty claim to Radsone?
Thank you!Try support@radsone.com . I used this address to communicate with them when I needed my unit replaced. It took them a while, and I really had to keep bugging them, but eventually I got a replacement. Good luck.
Does anyone know how to submit a warranty claim to Radsone? I couldn't find any warranty information on the Earstudio website, Amazon, or my box. My 3.5mm output suddenly stopped working correctly. The left channel is just gone. Tested with 3 different cable/earphone combinations, same result. 2.5mm output is still working. I bought my ES100 from Amazon in May.
I would, but the order page says: "Return and product support windows have closed".If you purchased it from Amazon would it not be easier to replace it with them? That is certainly what I would do in the same situation here in the UK.
