Radsone EarStudio ES100
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
201 202 203 204 205 206 207 208 209 210
212 213 214 215 216 217 218 219 220 221
  1. psikey
    I'd give the Fiio BTR3 a try too if your headphones are not too demanding and your not bothered about balanced out.
    I had the ES100 and while it sounds great I wasn't impressed with design/materials especially for £90 so that went back to Amazon. Controls too fiddly too.
    Now have the BTR3 and to my ears sounds just as good as the ES100 3.5mm output with enough power to drive my HD660S 150 Ohm headphones (max is too loud) yet still great feeding my SE846 IEM's with no background hiss/noise. Build quality is SO mush better especially considering nearly half the price for me (cost me £49.50 from AMP3).
    I'm keeping this one. Wired out of Quad DAC in my V30 is still slightly better but LDAC ay 990kbps is fantastic for streamed media including Tidal MQA Masters.
    monsieurfromag3 and Egoquaero like this.
  2. monsieurfromag3
    It is a big ol’ lump of cash, isn’ it? As a VK-2 owner I had a chance to pre-pre-order the VK-X before the Indiegogo campaign was even launched, at a ridiculously deep discount. Aëdle are special in that they go for design as a priority but still pay huge attention to sound quality.
    As an aside Beyerynamic’s wireless Xelento iems are even more expensive.
    Aëdle will probably launch a cool BT receiver soon in the shape of a circle, all anodized aluminum. The object itself already exists but it comes with MMCX connector cables, it’s designed to pair with their line of iems. If they do release the same thing with a 3.5mm jack, as they are considering, it will beat even the BTR3 on design and craftsmanship.
    trellus likes this.
  3. Lurk650
    Has anyone else noticed that if they set the quality 990kbps in Dev Options you have to reset it next time you use the ES100, it resets to the default Optimized Quality. FWIW, I don't even notice a difference between the two qualities anyways
  4. mhoopes
    I’m not commenting on Android or any portable device operation, but LDAC with the Sony UBP-X800 Blu-Ray player has 2 modes, and “Quality” has always delivered 990 Kbps for my ES100, with lower latency than AAC on my iPad Pro.
  5. Lurk650
    Yeah just got home so I tested it. Turned on the ES100, went to Dev Options and under LDAC it was set to Adaptive Bit Rate which is Default. Changed to Quality (990). Cycled ES100 and it was back to Adaptive.
    Easier just to leave on Adaptive. Also, when I had the Galaxy S8 it would always stutter on 990. Don't recall on the Note 9.
  6. tuckers
    trellus, Wambo and waynes world like this.
  7. plakat
    Having received my 64audio N8 recently, i‘m Now actually using the ES100 (before that it was the SE846 with Shures own Bluetooth cable).
    Besides good sound quality without dropouts (source is an iPhone, codec in use is AAC according to the EarStudio application) it offers good battery life, good handling (i can tell the buttons apart without looking and they don’t press too easily/by accident). I also think the SPL estimation is a nice feature.
  8. waynes world
  9. Lurk650
    Amazon offering a $10 coupon right now, making it $89.99 with Same Day shipping
  10. mhoopes
    Quick tweak: I added some Bondic UV-cure 1-part resin to the buttons on the ES100. It works well, though I might redo them to reduce and harmonize the protrusions a bit:
  11. Rowethren
    Really cool mod!
  12. Chessblitzer2017
    Just found out about this after ordering the smsl iq(da3 with a battery) a few days ago too pair with my xelento. seen the reviews, seen the looks/bluetooth, seen the price, $ought. Both around same $$. The 3 will be waiting when I get back home next week and will provide the iq vs es100 rookie nonaudiophile findings.
  13. peter123
    I've got both and enjoy them both equally much. They're quite different sounding and have usage areas for me so I'm perfectly happy with owning both of them.
    scotvl likes this.
  14. Chessblitzer2017
    I think you should expand and go in more depth with that as these are both widely praised amp dacs. You have so much experience, please delve further into the distinctions of the 2. People would appreciate it. Know I would. Thanks!
  15. notyourtree
    I would also like to see the ability to save the impedance and sensitivity settings into profiles to accommodate the different headphones/earphones I use so I can better estimate the volume and preserve my fading hearing a bit longer. That said, I am still very happy with my purchase, and greatly appreciate the continuous improvement and customer focus.
