Radsone EarStudio ES100
Sep 23, 2018 at 12:29 PM Post #2,791 of 6,675
Thanks for the heads up. I didn't want to change the firmware mid-review for the sake of consistency (and fear of bricking it in the process haha). I updated to 1.4.2 just now. Time for some testing ^_^
Nice review there Crabdog but honestly, ES100 will be irresistible if it incorporate the newer AK4376A DAC instead of the outdated AK4375A. I guess the AK4375A DAC is chosen instead to keep the ES100 price as affordable as possible.
Sep 23, 2018 at 12:46 PM Post #2,792 of 6,675
It's hard to say really. They (AKM) say the AK4376A has even better sound along with better performance but that's just marketing speak until I hear it for myself. As you probably know, the way a DAC is implemented has a great impact on sound performance and it's obvious that Mr @wslee has got some serious engineering clout. I am hugely impressed by the audio quality of the ES100 regardless of what DAC it has.
Needless to say though, if ever there is an updated version of the ES100 I will be all over it like a drunk uncle at a Christmas party :wink:
Sep 23, 2018 at 12:52 PM Post #2,793 of 6,675
Lol Crabdog...I guess I'll get myself an ES100 for Christmas after reading your review...even with the AK4375A DAC. Thanks to you.
Sep 23, 2018 at 12:56 PM Post #2,794 of 6,675
4376 only better without load (no headphones). Under load it has exactly same specs.
Sep 23, 2018 at 1:00 PM Post #2,795 of 6,675
Awesome! I'm sure you'll love it just like everyone else does. Looking forward to your impressions.
Sep 23, 2018 at 1:08 PM Post #2,796 of 6,675
Irresistible just the way it is. Thanks.
Sep 23, 2018 at 1:19 PM Post #2,797 of 6,675
The A4376A sounds like it would be great. However, it does take more power and that is important in these tiny devices.
- AKM says that the A4376A uses 36.6MW in HP Mode, and 13.7mW in LP Mode, (fs=44.1kHz). While the A4375A is 9.5mW (fs= 44.1kHz),
- Not sure if HP (High Performance Mode) is needed, but that is almost 4 times the power usage.
Sep 23, 2018 at 1:26 PM Post #2,798 of 6,675
This most likely explains my battery performance issues between the ES100 and the Fiio BTR3. Thanks for the technical info!
Sep 23, 2018 at 1:49 PM Post #2,799 of 6,675
Looks like it will be a very early ES100 Christmas present for myself then :)
Sep 23, 2018 at 1:54 PM Post #2,800 of 6,675
Not sure where you got those numbers, but 75 is not 9.5mw maximum usage. It's even more than that output power from specs. I bet they both identical in terms of power efficiency. They are largely same chip except that 76 has separate lp mode for almost no load scenario, like using dongle with external amp.
Sep 25, 2018 at 2:10 AM Post #2,804 of 6,675
Thanks to Oneplus removing the headphone jack on their next phone I have decided to get an ES100 which I will clip on around my shirt collar/ top button. What is the general consensus on cable length to the headphones in these situations? I was thinking about 40cm but not sure if that might be a bit long or not.
