rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
http://www.larrykinglaw.com/electrocution.htm
http://www.etms2.com/images/electrical/Slide4.GIF
http://www.etms2.com/images/electrical/Slide2.GIF
http://www.etms2.com/safety/electrical.htm
http://www.cpsc.gov/cpscpub/pubs/5040.html
http://www.epanorama.net/documents/g...grounding.html
http://www.epanorama.net/documents/g...al_wiring.html
from here
http://www.epanorama.net/documents/g...e_solving.html
hell I can go on all day providing links but have zero desire to do so.Any and all are welcome to do whatever you want up to and including walking off a cliff if that is what you personally desire to do.I have better things to do with my time than argue safety with anyone who would even contemplate unsafe measures that can actually risk a life just to get rid of "hum".
The fact that 90% of you have ZERO conception of what constitutes a ground,what IS ground isolation or Triple Isolated or what is and is not deadly but are willing to post nonsense without checking says to me go for it ! DO IT ! KNOCK YOURSELF OUT !
Me ?
I live in the real world where my safety and the safety of freinds/family/co-workers means more than cutting corners instead of finding solutions because it is easier.Ask any P.A.sytem installer (roadie) about the AC distribution system set up and why it is done the way it is.
(Because killing the lead guitar player of the band through electrical shock when all he tried to do was adjust the amp volume is not a real good way to keep your job is why !
http://www.equitech.com/articles/rep1.html
do what you want folks.This thread is no longer one where anything I could possibly add would be a wakeup call since there are obviously many experts here in electrical system wiring and my twenty + years are but a bad dream
Audio+video and computer systems with many grounded equipments Even if you have multiple mains sockets in your room, to take the power for everything from a single socket (run it through a mains filter if you want), then connect everything to that as a tree. Sometimes buildings are wired with a lot of electrical distance between the separate sockets in one room, so this trick can avoid many problems. If this doesn't work, call in an electrician to make sure that your buildings earth actually works at all - you could be risking your life otherwise |
from here
Me ?
