rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
That is damn strange dude.i have never had a radio station enter through a mains cord but only line level where it was "received" and amplified by a gain stage.
Sounds like it is time for both a ferite blocker on the AC cables just in case the RFI is an "airborne" transmission,put them as close to the inlet as you can get them,combined with a good CLC AC mains filters.
Best scenario would be to get them inside your audio gear by removing the present IEC inlets (assuming that is what you have) and replacing them with the types that have the built in RFI filters if there is room.Cheap and easy fix.
If not then you need an "out of the box" fix and that can mean anything from simple and cheap to expensive and a pain in the a*s but if you are up to it totally doable as a project.
a bit more radical is something like this ;
http://www.triode-systems.com/module...p?articleid=26
