i'm upping this topic with an ******* question, but i don't care of it !
I'm going to buy JH13 Pro at an headfier, and i don't want to take part of a reshelling process, so i was searching for making my own custom .. And i found this, do you think it's a "great" idea to put some of this thing on the ciem ?
FYI, i'm from France, so i have to pay customs + expensive transport fees ..
i have done the silicone mold thing myself using RADIANS kit and westone and its worth it in my opinion... i did not create a deep canal impression,, the material was cut down to the tip of the nozzle ,,, the fit is natural doesnt even feel like im wearing them and i think the sound is a lil cleaner due to nothing extending past the edge of the nozzle..
How do you attach and detach the iem from the mold? Does it just naturally fit so snugly together, or do people put any sort of sleeve in the hole the nozzle fits into? Does the fit get looser if you change tips several times?
If I understand correctly, it is basically the same material, but a slightly firmer mix. I played around with the Radians stuff a bit on this thread and this thread.
